PINKY355
- Jan 1, 2008
- 44
- 0
- 0
- VN HSV WAGON
1990 355ci HSV WAGON NOW WITH COME MANIFOLD
ENGINE: Balanced, honed and Blue printed 355ci, Come crank , Chevy I beam rods, Hypereutectic flat top pistons, ARP main stud kit, race bearings, crane 286 cam, 10-1 compression, moly lifters, HV oil pump, double row timing chain, Hi energy sump and Gilmer belt drive.
HEADS: Decked, Ported, port matched, 2.0mm & 1.6mm S/S valves, Crane 1.65 roller rockers, double v/v springs.
INTAKE: COME RACING TTB with 100mm snorkel, K&N pod filter in custom housing with cold air intake from under the guard. Big injectors and hiflow fuel pump.
COOLING: New 4 core radiator and clutched fan.
EXHAUST: Pacemaker tri Y headers into high flow CAT and 3” single system.
POWER: 332rwhp at 6500rpm.
GEARBOX: Toughened T700, shift kitted, with 3000rpm hi stall and lock up.
DIFF: VL TURBO LSD with 3.73 gears.
BRAKES: PBR twin spot callipers with slotted rotors on front. Original callipers on rear with slotted rotors and bendex ultimate pads.
SUSPENSION: FE2 spec suspension with 18inch alloy mags.
INTERIOR: Original Berlina spec interior with leather trim, aircon, cruise control, power steering, central locking and power windows. Previous owner did fit a different drivers seat.
EXTERIOR: Original paint and body kit. Paint still polishes up nice for 17 year old car but obviously has the usual close inspection blemishes. Original SV mags saved in the shed to be shod with MT street radials for (Woop arse Wednesday) sessions.
STEREO: Alpine 45w x 4 deck with 4" fronts. Rears are 6"x9" Boschmann and 2x 12inch SONY subs in a custom ported enclosure. Response 4x130watt power amp to drive the rear end. Seen 123db on the sound meter with a great sound and tight and deep bass.
OTHER MODS: Vented Group A bonnet scoop to try and feed cool air straight through the manifold tunnel (between the runners and the plenum). Only works if the throttle body engine cover is removed thou.
