ppd355
ppd355 submitted a new Showcase Item:
1993 Holden Commodore
Read more about this showcase item here...
The engine was rebuilt with a Wade Performance 1365a cam, custom headwork and match ported, heads shaved 35 thou block decked 20 thou, three angle valve seats, Crow double coil springs, 9.9:1 comp., ACL pistons and rings, all new bearings and lightened flywheel.
65mm throttle body, SS cold air intake, K & N air filter and Pacemaker headers and 2.5” Redback cat back system.
Tune and Chip by Electronic Automotive in Thomastown, for 143rwKW @5600RPM. Limiter set at 6000rpm.
Gearbox is a Borg-Warner T5 and is fitted with an Exedy Heavy Duty Clutch and a short throw shifter.
Diff was rebuilt with an LSD centre and 3.9:1 diff gears and rebalanced tail shaft
