Weglee
- Jun 13, 2017
- 42
- 4
- 8
- Location
- Ipswich Queensland
- VT executive
Hi sorry in advance as this will be a long one and I could not find one that exactly fits my issues.
Not sure when this started but has been an issue for awhile.
I have a 1997 series 1 Vt Commodore which has a few modes but had been running like a dream for ages untill one day i had stop to do something and when i got back in it would start but was idling like a bag of **** and when you put your went to rev it it sounded like it was not getting enough fuel (gurgling). I turned it off and pop the bonnet dumb founded so closed the bonnet went back inside for about an hour came back and it started perfect, so I drove it home and drove perfectly. Didn't drive it for a few days then next time it happened while I was driving so pulled over and rang for a tow truck and bought it home.
Did some research and checked for codes by bridging the with wire and the only code that came up was 12, and as of yesterday I have changed and in this order
Crank Angle sensor
Fuel Filter
Fuel Pump
Plugs and lead
Changed back to old coils and clean plate (was a suggestion from neighbour )
Check throttle body which looked ok
MAF looked ok
New o2 Sensors
New coolant temp sensor
had done oil and filter only about a month before
checked for air leaks.
Before doing the O2 sensor and the coolant sensor (while waiting for the deliver) it started and idled perfect so I took it for a quick drive down my street which is a culdesac as I was turning right it started running lie it was starving for fuel again so parked it and waited for the delivery ( yes ebay on a budget)
So I changed O2 sensors and the coolant temp sensor, started it and sounded perfect put it into drive and same as before running like **** same as before.
So I am very frustrated as I don't know what else to do.
So please help if you can (I am a female trying to do this as don't have any one to help so be nice hahahahah).
And I just notice there was coolant coming out of a bold in the head while I was idling (pic attached)
Crank Angle sensor
Fuel Filter
Fuel Pump
Plugs and lead
MAF looked ok
New o2 Sensors
