Tom1990
400hp VY
Tom1990 submitted a new Showcase Item:
2003 Holden Vy ii
Read more about this showcase item here...
2003 Holden Vy ii
Always garaged.
Never smoked in.
Serviced with full synthetic oil every 5000-6000kms.
Following Mods are:
226/231 custom grind cam. 550" lift
241 custom CNC machined heads
Dyno tuned to 400hp at the wheels
Heavy duty valves and springs
25% under drive balancer
Full top end rebuild with gaskets
VY maloo extractors with standard cats with 3" pipe out
Twin xforce 3" cat back
Nascar drive belt
Textralia twin plate HD clutch
OTR intake
Mafless tune
3.9 diff gears
High performance power steering pump
Kingsprings superlows rear
Pedders low front springs
New front and rear main seals
New Sump gasket
New ARP head bolts
New Slotted and drilled front and rear brakes
VE SSV wheels (245/35/19)
New Nolathane front bushes
New ball joints
New fuel filter
New nolathane lower control arm inner bushes
New PCV valve and hose
New Century high performance battery(2yr warranty)
New rear Monroe GT Sport shocks
New NGK platinum spark plugs
New Bosch high performance leads
New Bosch premium O2 sensors
New genuine throttle body
New genuine TPS
New genuine Idle speed motor
New nolathane diff mount
New HD sway bar links and nolathane bushes
New bonnet struts
New quality soft cover
Non slip rubber matt in tray
Phillips HID headlights, LED white parker globes, LED white numberplate globes, LED white interior globes
Black ADR approved bucket drivers seat
Oil pressure gauge and water temp gauge
Cruise Control, Electric evrything, Air conditioning, Genuine floor matts, Air bags
Comes with ELM327 wireless diagnostic device
Alpine Type R 6" speakers with tweeters proffesionally fitted
2 Channel amp under the passenger seat
Standard head unit with custom aus cable plug in
Whole sound system looks standard but is very high quality
