2004 VZ SS 5.7Ltr Auto "almost" stalling on startup
ZOOTV
Australia
2004 Holden VZ SS Commodore
Hi Guys,
I have a 2004 VZ SS Commodore, it's an automatic. On cold starts "Left for approximately 1 day" the car when started will drop to 500rpm and almost stall then go immediately to normal cold start rpm. It has been doing this for about 6 months and I changed the plugs and leads about 3 months go and it continues to do this most mornings whether it is warm outside or cold. Has anyone any ideas about this?
ThunderVZ0410
Holden Ute Thunder S
I had a similar problem with my car, but mine would stall and start good the next time. I changed the fuel filter and stopped using 7-11's fuel and that hasn't happened since. Just throwing in some ideas
ZOOTV
Australia
I will look at the fuel filter, wouldn't hurt to change it. The fuel I use is Shell V-Power, Caltex Vortex, BP Ultimate and on the odd occasion Mobil 98. Thanks for the idea with that one ThunderVZ0410.
ThunderVZ0410
No worries, all the best and let us know if you find out the problem :)
ZOOTV
Australia
I'm gonna give the Aeroflow AF610-05 - 30 Micron Billet Fuel Filter 5/16" Barb a crack and see how it goes.
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
It won't fit your factory fuel line fittings for starters and wouldn't be worth the hassle of changing to anyway
Just replace your fuel filter with a normal replacement
Ryco Part# Z586
Rocket 007
58
Vz cross8
I had a similar problem with my 5.7 and i took the throttle body off and cleaned the carbon out of it and problem fixed
That was 3yrs ago and changed from shell premium to caltex premium
ZOOTV
Australia
Thanks Matt, duly noted, I didn't realise it wouldn't fit, Just liked the idea of the filter changes with it.
ZOOTV
Australia
Hi Rocket,
Throttle body is nice and clean, just noticed the low revs on cold startup 500rpm and occasionally driving down the road from home and turning left and going up the hill to work, the car will lose power momentarily. I think it's the fuel filter.
ZOOTV
Australia
...............Incorrect post..
