20x8.5s on a VS?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by SaGe, Jul 26, 2006.
  1. SaGe
    SaGe New Member
    VS II S-PAK Manual
    will 20x8.5s fit on a VS?
    as far as i knew 19x8 was the biggest u could fit but the guy down at autopro said it would fit with no dramas, is he tellin the truth?
  2. VR_Project
    VR_Project New Member
    Bunbury WA
    MWS Improved VS Ute
    might need to roll the guards and extend a couple of things first... but where theres a will theres a way :yeah:
  3. statement
    statement reaching new limits
    north but not to north
    VY/VZ Calais/Tonner
    yer man like VR_Project said, cause 20z are getting more common on vs's an i spoke to a guy about fitting 22z, he said no worries but the tryes will wear alot quicker, but 20z won't be a big as a problem
  4. hayds_12
    hayds_12 New Member
    Lameroo, SA
    VS Commodore Series 2
    i want to kno how much space is under those ve arches if the ssv comes standard with 19s anyway im waitin to get me sum of those
    and as VR_Project said (where there is a [wheel] there is a way)
  5. VR_Project
    Bunbury WA
    MWS Improved VS Ute
    i hear that the VE can fit 20's in the wheel arches without adjusting anything at all...may have been a rumour, but if u could then thats wikid!:D
  6. sircruisealotVS
    sircruisealotVS Well-Known Member
    South Brisbane
    VZ LS1 Calais
    20's will fit, thats no problem...having it legal is where some other moddification come into play.
    in order to have no scrubbing you will have to pump and roll the guards...how you setup the suspension will also have to be well thought out, as having such large rims make suspension travel pretty scarce.
    shortened bumpstops, short travel adjustable shocks, and the right choice of springs (most likely not much lower than stock) will be needed.
    you will also have to have get a mod plate to keep authorities happy.
  7. holden007
    holden007 VRII
    Subaru Liberty
    20' let alone 22' rims, very expensive and rough ride.
  8. _Mukas_
    _Mukas_ DJ Titan...Hardstyle guru
    Edithvale born n bred...
    VR 5.0L Statesman
    and youll look like a muzzlord, a wannabe gangsta, or just a plain wanker with 20"+ on a commo.....
  9. HIROLLA
    HIROLLA Member
    vic
    VS SIII CAPRICE
    20z fit well atleast on my Statesman 20x8.5
    No rubbing or rolling or anything.
