300kw GTS tune
VR38
VB SL/E
How can I tell if my VY PCM has the standard tune or the 300kw tune?
Ginger Beer
Dunnydoore
Put on on a roller dyno and see
Or run the calcs for your time at the 1/4 mile, at a very rough off the cuff guess you should be in the 11's with a MPH around 115 mph trap
07GTS
Australia
VEGTS BUILT BLOWN E85
do u have a MAF ? also if no mods are done then u cant just put in a 300kw tune and have it work the GTS had a camshaft and such to make that power
Jeda
WN Caprice V
11's with 300kw at the flywheel?
VR38
VB SL/E
Have MAF and mods, don't care about power, just want some information on how to identify what tune I have, whether it be MAF or MAFLESS, 300KW or 245KW or 235KW etc etc
VR38
VB SL/E
Looks like I will be off to the dyno, maybe after I change the final drive...
vr304
Auckland, New Zealand
2007 ssv manual
If you’re wanting a tune then get a good custom dyno tune for your vehicle and mods rather than muck around with a factory tune for another model
markalan1two
Smile and wave boys !!!!
52
NSW
X5 BMW, GenF2 GTS, HSV Y R8, AMG C43
back in the day, when they did the GTS tune they would usually go to a mafless tune so if you still have a maf id be leaning toward standard tune.
Jeda
WN Caprice V
If your car has been tuned for the modifications installed, it won't be a factory file, it'd be a custom tune.
As Ginger Beer said, chuck it on the dyno and see what it runs.
