304 Replacement Rocker Cover Bolt Sets
LXCHEV
44
Melbourne's Outer East
VR Calais, VS Berlina & LX Torana
Chasing a full bolt set (including washers/seals) to suit the factory 304 rocker covers. Keen on brand new. I found an old post in the SHYGMH thread showing part numbers for ARP gear (and they do look awesome) - but I'm after a simpler/more factory solution.
Currently looking at ebay seller "holdspares" who advertise 2 sets - plain with no seals, or stainless with seals. I reckon the stainless set looks the goods.
Before I buy - should I be looking anywhere else? I was thinking of going to the local bolt shop - just not sure if they'd have appropriate seals?
LXCHEV
44
Yeah agreed, I think the stainless set looks fantastic. Since I don't have anything as a starting point, I'll take a punt and give it a crack.
NORTI
Radelaide
Wildtrak
Holdspares is doing a decent job of sourcing kits like this.
I begrudged some of their pricing & NOS hoarding, but the father & now son combo seem to be doing okay.
I will likely end up buying some things off them soon as well.
I would go the stainless with the seals.
BlackVXGTS
Melbourne, SE
Looks good, but those leads look a bit untidy. You need something like the picture below.
What's the gap in the front of the inlet manifold with the two tubes going back inside? Is that standard?
Deuce
Super Stock
'94 VR SS V8
Yes manifold vacuum ports. From memory:
One to the map sensor (larger size) and the other smaller one is fuel reg.
LXCHEV
44
Correct - vacuum ports are:
1. Fuel pressure reg (small one on left) - FYI - I used 4mm ID vac hose;
2. MAP sensor (larger one on right) - FYI - I used 6.5mm ID vac hose
I'm still putting this thing back together, working it all out as I go. Previous owner had left a massive mess - lots of incomplete bits. Really enjoying the process of nutting it all out.
The spark plug leads are just loosely sitting there for the moment - haven't paid any attention to them yet. I have some nice looking separators that I need to play with. Probably won't use the factory lead brackets that attach to the rocker cover lower bolts, but not sure yet.
It'll be a shame to install all the heater hoses, as they look so messy!
  • Like
Reactions: Lex
LXCHEV
44
Should have also mentioned - I got the stainless bolts for the fuel rails from holdspares too.
