304 V8 rotating assembly measurements
Watejs06
Gwelup
VS SS Ute
Hi all,
Long time reader, only just made my way back into a Holden V8 powered car, well Ute (1999 VS SS, manual)
Wondering if someone can help with the below questions, as I'm getting many mixed results & differing information.
1. What is the stock 304 connecting rod length ?
2. What is the stock 304 piston compression height ?
Slightly different topic:
Am I right in assuming that a 355ci stroker with 5.7 inch connecting rod is actually a Chev kit (308) ? As there seems to be 2 connecting rod lengths available ?
Thanks all.
Jay
Deuce
Super Stock
'94 VR SS V8
Hi all,
Thanks all.
Jay
I'll do a measure soon.
But yes, a Holden 355" stroker kit is basically a chev 383" stroker kit with a different crank.
Holden 8.8deck height. Chev 9.0 deck height if I remember correctly.
Both can be 5.7 or 6.0 rods.
There is generally a few hundredths in it for remaining piston height below deck, but nothing that cannot be sorted decking/skimming/or thinker gasket.
Deuce
Super Stock
'94 VR SS V8
(all measurements, approximate and in inches)
Stock rod measures 5.667
Compression height is pin divided by two, plus top of pin to top of piston.
(0.925÷2)+1.265 = 1.7275
keith reed
76
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
I used the standard Holden rod with a Come racing crank. They make one for the 5.7 rod as well. For me it was a matter of economics.
Watejs06
Gwelup
VS SS Ute
Thanks mate, appreciate the help.
I see that the 355ci Stroker is the go to rebuild, everyone seems to go down that road. But I'm considering a well put together forged 304 build, mostly for something different.
Deuce
Super Stock
'94 VR SS V8
Well make sure to get good compression, cam it well AND REV IT!
Immortality
Staff member
Sth Auck, NZ
304 stock stroke - 3.025"
Rod length - 5.627"
Piston compression height - 1.71"
A Holden 355" stroker kit is 3.48" same as the Chev 350 with 4.020" overbore to give 355 cubes.
Scat (Holden) 355" stroker kits come in 2 options, either Holden or Chev journal. The Chev journal is wider than the Holden so you can't swap rods between the 2. Chev journal cranks have lighter counterweight which means balancing the rotating assembly can be more problematic if you end up using heavy pistons. Now where it gets even more interesting is that you can now get Scat Holden (journal) 5.7" rods.
For more info
Watejs06
Gwelup
VS SS Ute
I am still considering boost, the Yella Terra 2.4L whipple system seems to produce some great results.
Watejs06
Gwelup
VS SS Ute
Rod length - 5.627"
For more info
[/URL]
[/URL]
Thanks mate, very informative. I appreciate the information. Much clearer.
Mottra
59
VT SS 304
What pistons did you use? Was it a good result?
