VT-565
How the hell can you multiply boost with multi power adders? That would mean with two turbos and a supercharger all putting out 10 psi you've got 1000 psi of boost? Me thinky not.
You're thinking about it the wrong way.
'Boost' or 'pressure' is a unit measurement of resistance.
If a power adder can flow more air than the engine can take, then pressure builds in the inlet tract.
If a car is already supercharged (in this case, positive displacement) then the inlet side of the supercharger will be at atmospheric pressure or below (vacuum), now put another power adder upstream of that, in this case, a turbo, then all of a sudden, providing the turbo can flow more air than the supercharger can pull through, there is an increase in pressure at the inlet of the supercharger, which then carries through into the inlet manifold, equalling more air in the same space.
Don't laugh at the 'multiple turbo' thing either, that technology has been used in diesels for a long time and is currently being used on an audi diesel powered Le Mans car.
Two turbos, set up sequentially, making over 50psi at the engine.
