355 stroker
CPT James t
62
Hobart tas
Vn commodore
Hi all, PLS help. My little 304 has been stroked to 355 scat kit, ,running VN heads, are the standard plug length ok .want plugs are you using.
Deuce
Super Stock
'94 VR SS V8
I'm still using standard plugs on mine.
Maybe go 1 grade colder if you have really good compression numbers, otherwise stick to exactly standard.
I'm using AC Delco plugs
BlackVXGTS
Melbourne, SE
I continued to use the standard NGK BPR6EF in both the 355 and 383 incantations of my VS Calais. Never had a problem or need for colder plugs.
MikeC
VQ Statesman
I don't have a stroker but every engine I own runs NGK plugs.
