[VIC] 5 Speed Conversion and Heads
DannyboyDS
Just hand me the pliers.
39
VS Berlina
ITEM: One T5 manual conversion for a V6, the flywheel is from a vn series one, but it comes with an adapter plate so it can fit all later models up to and including the ecotec.
Comes with the standard speedometer (Transducer) and a special speedometer that functions exactly like the stock one except that it produces a PWM signal like the 4L60E auto, which your auto computer can interpret correctly, Also proved is a special tune by Ejukated which allows it to function.
Please note the special speedometer is untested, in which case you might have to review the manual conversion thread in the "how to" section for setting up the speedometer.
There should be everything included, as well as two shifter knobs, two starter moters and an adapter shim for the starter moters (Some cars require the shim)
LOCATION: Victoria, Melbourne eastern suburbs (Willing to travel and meet half way)
CONDITION: Used
PRICE: $600
DELIVERY/PICK UP INFORMATION: You can pick it up from me, or we can meet half way if the distance is a bit much.
PAYMENT OPTIONS: COD
CONTACT DETAILS: PM me or reply here
OTHER INFO: Its second hand, its a manual conversion, you want it, I want the money, lets not muck around.
PICTURES:
ITEM: Two Reconditioned Heads from a VS V6 Ecotec
CONDITION: Used (Technically)
PRICE: $300
OTHER INFO: They have been fitted to an engine and ran for several minutes without fault, this grants them the wonderfull title of "used" however for all intents and purposes they are reco'd, generally thats about $800 worth of heads. Keep in mind they are stock as a rock.
PICTURES:
Or you can have the lot for $800 if you so choose.
VXSS32
VX SS
Very interested in the t5 conversion. Does it come with everything needed for the conversion? Like the console and tailshaft and stuff. Also what did it come out of and did you use it? Are you able to tell me the condition of the box? Also where abouts are you
DannyboyDS
39
VS Berlina
The pictures for the manual conversion seem to be up the duff, i'll re-upload them on sunday. Yes everything is provided, including the center console surround.
As stated above its all from a VN series one sedan, if you have a ute or wagon you can take the yoke off of the tailshaft and put it on your existing shaft, you will however need to fork out for a $30 uni joint.
No I have not used it, as far as I know its in A1 condition as sold to me, the only reason i'm selling it as i'm selling my VS and no longer have a need for it.
DannyboyDS
39
VS Berlina
ok ive added the photos for the manual conversion, sorry im doing this all on a mobile phone (Except actually taking the photos) I have no interweb on my PC now :(
the center console isn't in the picture i'll take one and put it up.
anyway thier it is.
DannyboyDS
39
VS Berlina
I really need the space guys.
Common
DannyboyDS
39
VS Berlina
Sorry mate without the flywheel all I have is a pile of random parts
social
Ute Finatic
South Aus
2012 VE Thunder
Nah you wouldnt mate im interested in;
- Gear stick
- Rubber spacer connected to the gearstick
- Centre consol surround
- Gear knob + gearstick boot
- Starter motor
- Pedal box
- Floor insert
- ECU
Im from adelaide but you should be able to pack all that into a box and post it (which im happy with paying for too)
Cheers,
Social
