5L problem
IhateRICE!
VNSS Atlas Grey
:bang:hey everyone
i recently sprayed Nulon Throttle body & Carby Cleaner in my TB of my 5L and ever since it seems to die, in the mornings even after i let it warm up and get abit of temp.. then i go for abit of a drive to and it just dies and is almost impossible to start. but once it's up to temp it's fine.. WHAT THE!!
it's been nothing but frustrating..
Any help would be great thankyou
pow3rslave
DoNothing Member
eastern subs, vic
VP 5.0L
just a thought, it might have loosened up some of the grossness , then pooled it into the tps or iac. id' take the tb off (or at least these sensors) and give it a once over if possible.
IhateRICE!
VNSS Atlas Grey
done that and replaced the IAC sensor.. with no succes i'm thinking it might be a fuel problem.. between to 2 pumps. how does the 2 pump setup work??
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
if it happened after a throttlebody clean without taking it off its normally the TPS as it fills up with horrible greasy carby cleaner and kills them.
IhateRICE!
VNSS Atlas Grey
but why is the car fine when it's warm if the TPS is full of ****??
