6 speed manual conversion
Bigbadberla
VX Berlina
Is it possible to fit a t56 into a VX berlina? Is a new bell housing required? Also, could you tell me what they are worth??? Thanks
WinterVX
N/A
Thats a good question, would be interesting to see if it could be done to a VT/VX model, I miss the old Berlina & Calais manuals
minux
2017 SSV Redline
Upwards of $5k for the box new. Then you need new radiator, remove all the old transmission lines, there are a few other bits and pieces like a decent clutch upwards of $1000, then you need a pedal kit etc, believe if you buy most thigs new you are looking arund the 8-9k mark fitted, this can be saved by going second hand which could mean the box may not last long :)
Bigbadberla
VX Berlina
Whad did u find out ripcell? Did you end up doing it?
