6 stacker CD standard in MY13 SSV Z Sedan?
Grumpyoldb
2013 VE SS-V Z Sedan Perfect Blue
Would like to know if a 6 stacker CD is standard in the SSV Z? Or is just a single CD?
rx2_freak
Smokes, let's go.
Churchill
SSV Z SERIES SPORTWAGON
Whats a CD?
Had a quick look on the holden website[found zero]. I would assume they're just a single cd, as you can rip the cd onto an internal flash drive. Although it says not available on Z series.
Grumpyoldb
rx2-freak you have a SSV Z so does yours have a single or stacker?
rx2_freak
Smokes, let's go.
Churchill
i dont know never put a cd in it. didnt know it had a cd player until someone poined it out to me afterwards. i just play it off bluetooth audio from iphone.
As above i assume just a single, will have a hunt around to try and find out.
Edit: Just found the IQ manual on the net[copied from it]:
Holden-iQ is compatible with most audio
formats, including:
iPod®
USB flash drives.
Bluetooth®
audio streaming from
compatible devices.
Portable audio device via 3.5mm auxiliary jack.
CD - Single CD-CDDA, CD-R, CD-RW, MP3
and WMA.
Radio - AM and FM.
Holden-iQ also has an internal flash drive for
storing up to 15 CDs (optional on Omega with
Satellite Navigation). The flash drive acts as a
virtual CD changer.
HEXEM
ACT
VE II SV6
The Holden iQ system only takes 1 CD at a time. However you can store 14 CDs on its internal memory. It will each CD. I is not like the Series 1 SSV which had a "6 Stacker" player where you loaded 6 CD and it then took time to load each one.
I only use my 16gb USB thumb drive to play my music. The only time I use the CD is if a mate has a CD I like, I will then rip is down and give him back the CD..
Wongy295
Donating Member
2012 VE SV6 (LPG)
The Holden iQ system only takes 1 CD at a time. However you can store 15 CDs on its internal memory. It will each CD. I is not like the Series 1 SSV which had a "6 Stacker" player where you loaded 6 CD and it then took time to load each one.
Fixed!!! :)
Grumpyoldb
Thanks for the info guys.
