hey man if u mind answering a question.. i just swapped the auto over in my vl for another auto i got for cheap and the car was running better than ever. didnt slop into gears and drone out the neighborhood and the note was much better. the car was going great for about 2-3 weeks then it starting getting very loud and sounding like it was running way too rich and choking on fuel. days after it started sounding like a tractor and i had to put it in neutral and rev it at the lights so it wouldnt stall. got it home and it wouldnt stall but would rev at wat appeared to be no more than 100rpm. i dont think there were even fault codes from memory. swapped the dizzy over for a new spare got new plugs and leads, swapped o2 sensor, ran injector cleaner,cleaned aac valve,swapped afm,checked dizzy angle and fuel reg still ran ****. than today i swapped the tps, aac, and that part with the idle screw that bolts to the back of the inlet manifold and the car ran preety good but still had a jump/pop in the exhaust note. the problem is now the car idles at 1500 rpm so i adjusted the idle screw all the way and its still at 900 - 1100. the throttle stop is fine and there doesnt seem to be any vacumn leaks, also the coolant temp sensor was on. do u have any idea what this could be and also how to adjust the fuel ratio so it runs near perfect and not too lean or rich. im running 95 in it and occasionally 98. thanks for any advice...
