the_boozer
no more VK
- Nov 7, 2009
- 1,564
- 826
- 113
- Age
- 51
- Location
- Shitsville Morwell
- hilux
does the alternator charge light work? if no the alternator isn't charging
Thanks mate, I’ll look into this tonight and see what I come up with.Definitely check the alternator. In an ideal world at about 1800rpm you should be seeing 14-14.4volts at the alternator (measure between the positive output stud and alternator body), then measure the battery voltage and they should be almost identical (allowing for a small voltage drop in the wiring). At idle you might find the voltage will be down a touch depending on how much electrical load you have on.
Hey man so I just did a diagnostic check got one flash then two so no issues there, it’s probably worth noting when it starts with a small rev added it starts misfiring pretty bad.Well the alternator sounds fine. I'm almost wondering if you have a vacuum leak. Check the vacuum hose that goes to the MAP sensor, these can go hard/brittle with age and the MAP sensor is rather important.
Have you cleaned the throttle body? The IAC controls the idle, maybe something going on with the IAC stepper motor.
I have also replaced IAC and TPS and CASWell the alternator sounds fine. I'm almost wondering if you have a vacuum leak. Check the vacuum hose that goes to the MAP sensor, these can go hard/brittle with age and the MAP sensor is rather important.
Hey mate I did that and nothing,After 3 flashes of OK (12), it may still thow a fault code. Let it run longer & see if it changes.
Sorted the vaccum leak out and car started first pop for the first few times, I’m starting to think my fuel pressure regulator has gone as I pulled the vaccum hose off and fuel came out it has also gone back to not starting properly and once started it doesn’t fire on all cylinders for a few moments and noticed the fuel gauge will stick for a sec before jumping to where it needs to be would the FPR cause that? Still cuts out whilst coasting alsoHey mate I did that and nothing,
I manage to find the map sensor hose was split, will fix it tomorrow when i can get some more vacuum one hopefully that sorts it
