97 vs berlina series 2
Vs executive
Hey guys ive got a 97 vs berlina series 2 with vt engine and trans and the rpm and speedo isnt working have got fuel and temp.. running vs loom ecu and torque converter..
Immortality
Staff member
Sth Auck, NZ
Seems odd if you used all the original VS wiring looms.
RPM comes from the DFI module, speed comes from the VSS on the trans via the PCM to the dash and they all use the same DFI modules and speed sensors.
Vs executive
The speed sensor on trans meaning the 2nd plug at the extension housing?
Immortality
Staff member
Sth Auck, NZ
Yes.
Immortality
Staff member
Sth Auck, NZ
Nope. Just search for Commodore speed sensor online and see what comes up. Should be fairly common.
Vs executive
No worries thankyou i found one on ebay.
Ive got another problem im chasing is that when up to operating temp the top radiator hose is warm but the bottom is cold and i can feel as if theres no pressure ive replaced the thermostat twice now as it feels like its staying closed but only letting a minimal coolant through to the bottom hose...?
Immortality
Staff member
Sth Auck, NZ
If the top radiator hose is getting warm than the thermostat must be opening, how long have you let it run? Once the thermostat opens it will take a little while for the radiator to heat up. Give it some time to fully heat through and watch the engine temps.
Vs executive
Maybe half hour at its most , temp gauge went to hot after a while idling ive replaced the sensor thats on the right side but havent replaced the one on the left.. also replaced the waterpump
Immortality
Staff member
Sth Auck, NZ
Sounds like you have an air lock which is quite common on these engines, use the bleed screw on top of the thermostat housing.
  • Like
Reactions: Lex
