- Apr 15, 2006
- 22,661
- 20,576
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
We are talking about these, when you do a search for VS you get this,
But if you look at VT-VZ onward you get this,
(yes I am aware the OP wants no ABS). Now I have a sneaking suspicion the later 4 hole VT-VZ units will probably bolt on the earlier VR/VS hubs but not 100% sure without doing some measuring (and would only apply to non ABS as it looks like the plugs are different). Also note the 4th hole isn't threaded.
The question becomes what is the 98 VS ute fitted with as there were a lot of VT parts used in the series 3 utes. Visual check is the only certain way.
edit: random interweb pics used.
