Acrylic + Thinners Ratio
Jecs
PAVTEK Race Engines
Staff member
'97 Caprice 355ci & VZ SS Ute
bit of advice needed.
im looking at spraying a bit of aluminum (approx 240x50) with acrylic black paint. i was hoping to spray it either this sunday or monday, weather around 21-24 degrees.
now from memory the ratio was 1:1.5 (1 litre paint, 1.5 litres thinners) just want to clarify thats correct and if anyone else has any general advice.
cheers
Jonno
Vic,
yeh 1:1.5 is about what we mixed it at mate!
good luck with the painting!
are u priming it too?
Jecs
PAVTEK Race Engines
Staff member
yep ive got it sittin in primer now. had the heat lamps on it today
Jonno
Vic,
yeh sweet, 1:1.5 should be fine, ask ARI anyway he knows his painting **** really well
showbags
SENIOR EL'BAGO
VT Calais, BMW 135 m sport
cheers
I hope you etch primed that aluminium first Jecs. For a better finish use a high quality acrylic thinner( not multi purpose or that **** you buy from SCA). With acrylic, if the ambient temp is over 20 degrees, I'd be using retarder as well why you not using 2k for such a small part?
Jecs
PAVTEK Race Engines
Staff member
lol dude u blew my mind. im not a panel beater.
heres what i did. scotch bright the fk out of it, prepsol it, used primer i had around.
i dont know how to mix 2pac and i cant remember the steps with it. using acrylic is alot more user friendly
showbags
SENIOR EL'BAGO
You should really etch prime aluminium, but in saying that, sounds like you've taken the time to scotch brite and clean properly. Just don't lay the first couple of coats on too thick. Take your time. Double your amount of thinners in your last couple of coats and you won't have to cut the fk out of it to bring up the gloss. Good luck.
Jecs
PAVTEK Race Engines
Staff member
cheers, thanks for that man. ill double the thinners in the last coats. see how it turns out
showbags
SENIOR EL'BAGO
Being a small part, if you fk it up, it's easy enough to sand and start again. Don't forget pics when your done.
hi_ryder
Donating Member
Pascoe Vale South, MEL
we spray painters get a kick out of when someone replies to paint advice with that line. i lol'd most panel beaters couldnt answer a paint question with a gun to their head...
what kind of elements will this aluminium be subjected to? indoor outdoor? also i know showbags has suggested to double your thinners on the last coat, just be careful, it goes on easier than it comes off. it wouldnt even hurt to test it on a scrap piece as a dry run so that you dont end up having to rubbing runs back (unless your painting flat) and recoating your larger one. adjust your gun and do test patterns before letting it rip...
