M
mikemutlow
Guest
Air Bag Warning Light
I looked for the pre-tensioner connectors last night and sure enough (as you said) they are green with a metal clip over them right down between the seat and the centre console. The one on the passenger seat is nice and tight and looks fine but the drivers side connector seems a 'wobbly' and the metal clip loose. I reckon this is a good candidate for te source of my problem. The only difficulty is access and it looks like I either need to remove the centre console or the seat to get at it. Any suggestions on which of these options is easiest?
I have concluded that I cannot set off the pre-tensioner by simply removing and replacing the connector as activation can only occur if there is a signal (ie. voltage input) from the accelerometers at the front of the car, and I will not be generating any voltage by disconnecting / reconnecting - right??
