For those interested here is a pic of where to stick ya probes. Someone metioned earlier some weird negative ohm readings. To fix that swap the probes around.
Also as a note when i had the car running i got no readings. i only got them with engine and ignition off.
Cant remember if this is the way the probes go or it they were swapped to get the right readings. Also note blue cap missing to get access to adjustment screw (to left of connector).
pins should be numbered on the top.
As a note to anyone going to try this beware, if something else is out of whack then the ohms settings may do harm. I adjusted the ohms my car didnt like it. It was because my O2 sensor is a little cactus. I would reccomend that if your doing anything more than a minor adjustment you go to a mechanic who has the gas probe that gets stuck up the arse end. Otherwise you really dont know what it is doing.
cheers
steve
