Good question.Hi Deuce,
So why do engines feed in at the bottom (return) then and exit (feed out) at the top ?
In at the bottom and out at the top will eliminate any trapped air.
Would there be air in there when you install, replace radiator or hose/pipe?You're kidding aren't you ??? it's being pumped through so there will be no air trapped at all and the pick up is submersed at all times, so not possible.
