After vats is removed from ecu will I still need to link my bcm-pcm?
Ja5e13
Newcastle
Vt series 2 clubsport 5.7
I've got a vt clubsport that someone attempted to steal and butchered pretty badly, ive had to do a full wiring harness swap and replacement bcm with matching key the car fires up and dies after a few seconds.
I had vats removed from ecu thinking it would be a quick fix but it still fires up and dies after a few seconds.
Can someone tell me if my bcm and pcm will still need to be linked even after vats has been deleted???
Or can someone point me in the right direction of what could be my issue
Tasmania, Australia
2000 VX SS, 1999 VT Berlina, 2000 VX Calais Super6
if you have a no vats ECU it will work with any compatible BCM without any linking through software
krusing
Melbourne, Bayside
Sounds like the immobiliser is still active,
You will need to get your Key re-programmed in.
27
Qld
vY berlina
Hey mate, I'm having the exact same problem, with my Vy. I swapped a new bcmand key, it fixed a problem I had with my blinkers, but now the car is starting then just cuts out. Did you find a solution?
krusing
Melbourne, Bayside
You need to get it all linked,
and the key programmed in again.
27
Qld
vY berlina
Linked by what? What's needed to link it? What needs to be linked?
Jeda
WN Caprice V
Bcm and ecu need to be linked. You'll need to go to a dealership or find someone with a bidirectional scan/programming tool to link the modules.
  • Like
Reactions: Lex
