the ac clutch on compressor is swtitched by a 12volt siganl
12 volts in one pin and earthed out other side!~
use a test lamp to check power getting to compressor
if not
check EVERY FUSE in engine compartment as maybe someone rewired it on you (ive seen this before)
else swap relay and see if clicks when ac is turned on car running
then get back to me.....
relay has no power to terminal/s?the compressor is getting no power to it. they relay is not clicking, how ever the relay is working, checked all fuses and are fine
