The bearing is spot welded into the pulley so you have to buy the whole thing which is around $300 from memory and you also need a special tool to pull the clutch off. I made one from assorted brass pipe fittings but I can't really explain how to do it. If you manage to get the clutch off then the pulley is held on by a circlip and comes off quite easily.
