VPRob
- Feb 10, 2011
- 1,120
- 196
- 63
- Location
- nowra, NSW
- VP executive sedan V6
sounds like you found the right guy at that rate
LPG based gasses like Emgas m30, m50, m60 r134y etc are mean't to be a drop in gas but over 3 years of playing with it for Lidcombe ice on the Tuggerah depot, the thermoking freezers on the trucks etc, these are the things I've learn't.
1 never be complacent with it, esp if you smoke in your car!!!!
2. for it to pull down in temp the same as 134a (or you can drop in r12 in it's place if you can find it) your need to increase compression power by 67%
3. it seems after 6-12 months to react with the oil in the system and then perform worse and worse and worse.
4. nobody really know's stuffall about the lpg gasses
5. there are no tx valves etc make especially for lpg based gasses and it can be a pain to get it right.
6. upgrade your condenser, you really need to pull the heat out of the gas really efficiently before it has reached the bottom of the condenser and become a liquid again or it'll go out on head pressure and just back off in pulling down in temp.
since the scrapping of the carbon tax, 134a isn't anywhere as dear as it was. Stick with what the system was designed for and it'll perform how it was intended.
