Alloytec 190 Water Pump cost
shueardm
VZ SV6
My SV6 is in with Holden getting a new A/C compressor and dryer fitted . I used them because they were cheaper ( $1200 ) than the other place I got a quote ( $1400 )
While it's being done they ring me to tell me my water pump is leaking and ( with a very sad tone ) advise it will cost me $1100
Now I do believe the Allotec pump is harder than the VT one I have previously replaced ? Is it a fair price and can I do it myself?
I have changed the spark plugs on this engine before so I have had the plennum off ( though it feels like a while ago and it's rather vague )
No way should I spend $1100 , am i right?
PS> I see the red coolant leaking myself but it's been like this for some time, not enough to affect temperatures yet.
figjam
Donating Member
Far Kurnell
FJ
It was a few years ago, but coolant flush, water pump, radiator cap and neck, three farnarkling attempts and disputed costs with dealer cost me $854.
That was my last visit with a Holden service centre.
DavesSV6Tonner
Australia
VZ S V6 Cab & Chassis
$1,100 to replace a water pump, they must be tripping on some really good ****.
I've replaced mine twice in the last 15 years.
Takes about an hour to do the job if you have everything you need on hand for the job.
Make sure you have a torque wrench and the torque specs for the bolts.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
$1100 is way over the top but they think they have you over a barrel.
one hour for a 72 year old including 2 beers
after market pump costs $91 retail premium, or $76 for cheapie
Add $53 for new coolant
FWIW I have never used a torque wrench on my cars
shueardm
VZ SV6
Are you that 72 year old and do you live in Adelaide? :)
DavesSV6Tonner
Australia
Never used one for a water pump replacement on the trusty old Holden red 6 but when it comes to these alloy blocks I don't trust myself to not strip a thread so I torque everything to factory specs to be on the safe side.
Immortality
Staff member
Sth Auck, NZ
wannaeatyourbrains
52
Mecca
VZ Executive
Yes, what robbery. Heart attack at the thought. Loosen the 4 x 10mm on the pulley. Pull off the serpentine belt. Take off the pulley. Few quick bolts around the pump, go back the other way and you are done. Here, a pump is $50 and the Dex-Cool $20, 4 bottles of distilled water $2. You can take the pump down to this machine shop I know too and they change the seals and bearing for $30.
$1100...never go there again.
Should fix it, but, cause if water is leaking it is going in the bearing and it may seize.
Jolls
Donating Member
Murrumbateman
VY SS Ute (Jimi Hendrix)
Dispute that charge for sure! Ask for a breakdown of the charges and then have him justify it. Watch him squirm.
