the_boozer
no more VK
- Nov 7, 2009
- 1,558
- 808
- 113
- Age
- 51
- Location
- Shitsville Morwell
- hilux
Being VZ is there an injector signal on number 2 plug in a noid light and see.
Is that sorta like a voltage tester? I’ve spoke to someone and they said it could be the injector of the piston which I’m leaning more towards the injector hopefully that’s all the problem isBeing VZ is there an injector signal on number 2 plug in a noid light and see.
Or the piston*Is that sorta like a voltage tester? I’ve spoke to someone and they said it could be the injector of the piston which I’m leaning more towards the injector hopefully that’s all the problem is
yes a multi meter would probably be able to test for a signal , my bet is the ecu if there was a hole in the piston the motor would sound rooted and the spark plug would look shittyIs that sorta like a voltage tester
Compression test will prove if it’s a piston,Or the piston*
Ok sweet will keep this in mind thanks for that will let yous know once it’s figured outCompression test will prove if it’s a piston,
Thinking out side the cylinder,
Could even be a roller rocker that has failed.
Sweet thanks will keep in mind, will let yous know what it ends up beingyes a multi meter would probably be able to test for a signal , my bet is the ecu if there was a hole in the piston the motor would sound rooted and the spark plug would look shitty
