DevilDRake
Braaaap
- Oct 14, 2009
- 1,156
- 60
- 48
- Age
- 32
- Location
- Skye
- Website
- www.devildrake.deviantart.com
- 2006 VZ SS 6L Ute
ITEM: Alpine Type X 12" SWX-1243D Subwoofer + Sledgehammer box!
CONDITION: Used
PRICE: $300ono
DELIVERY/PICK UP INFORMATION:
PAYMENT OPTIONS: COD
CONTACT DETAILS: PM or message me 0413428005
OTHER INFO:
Hi all,
Selling my Alpine Type X 12" subwoofer, Dual 4 ohm voice coil (SWX-1243D) in a custom Sledge Hammer box. This thing absolutely hits hard! Really clean and low bass in a near new condition!
The front cover for the box doesn't fit on with the Type X, as it has a huge surround on it, but it will be included with the bolts.
Pickup only in Cranbourne, Victoria. Any questions please contact Kyle on ******8005 + click to reveal .
It is currently in the car, and will take one minute to take out so you can hear it before you buy if wished, let me know.
SPECS BELOW
SWX-1243D12" Subwoofer
Features and Specification
SPECIFICATIONS
Power Handling
Power Range: 500 - 1000 Watts
RMS Power Handling: 1000 Watts
Peak Power Handling: 3000 Watts
Dimensions
Mounting Depth: 219 mm (8.6'')
Mounting Diameter: 277 mm (10.9'')
Displacement: 0.194 cu. ft. (Front Mount)
Added Volume: 0.079 cu. ft. (Reverse Mount, Magnet Out)
General
Frequency Response: 24Hz - 200Hz
FEATURES
Diaphram
Material: Kevlar RohacellA? Layered Composite
Design: 1-Piece Parabolic wtih Vented Force Transfer Assembly
Surround
Material: Injection Molded SantopreneA?
Design: High Amplitude Multi-Roll (Patent Pending)
Spider
Material: NomexA?
Design: Mirrored Progressive
Voice Coil
Material: 220A?C Aluminum Wire on Twin-Wall Aluminum Former (Patent #6,292,079)
Design: 6-Layer 4I? Voice Coil with Inner/Outer Winding
Motor Structure
Pole Geometry: Compound Radius Curve (Patent #6,639,993) with T-Drive
Configuration: Billet Copper Shorting Sleeves with Heat Dissipation Plate (Patent Pending)
Frame
Material: Cast Aluminum
Design: Perimeter Vented Exo-Frame (Patent Pending) with Integrated Spider Landing (Patent #6,678,387)
Terminals
Layout: One Side
Design: Insert Terminal Blocks with High Current Voice Coil Configuration Jumper
Tinsel Leads
Design: Reinforced Layer Spider Integration (Patent #6,810,988)
Gasket
Design: Concealed Mount Design with Front/Rear Sealing Gaskets
CONDITION: Used
PRICE: $300ono
OTHER INFO:
Hi all,
SPECS BELOW
SPECIFICATIONS
Power Handling
Dimensions
General
FEATURES
Diaphram
Surround
Spider
Material: NomexA?
Voice Coil
Motor Structure
Frame
Terminals
Layout: One Side
Tinsel Leads
Gasket
