Ambient air temperature sensor
Lumina2008
42
Usa
Holden commodore 2008 v6 ve
Hello every body
I hope one to help me to find the location of ambient air temperature sensor and the cabinet temperature sensor as a/c is not working sometimes and other times it work properly and many technicians examin a/c system and found nothing wrong in the system so I think it may be a temperature sensor issue...
Holden commodore 2008 v6 ( caprice Chevrolet)
Fu Manchu
WA.
The cabin air temp sensor is in behind the dash panels on the drivers side.
Might be able to get to it from under the steering column or with cluster out. I’m a bit foggy on that from when I did it.
The sensor for the evaporator is also down there and there’s a mod to pull it out a little to get a better reading.
The ambient temp sensor is from right behind the bumper. So bumper off to access it. In where the radiator is.
Lumina2008
42
Usa
Thank you for reply , I will try to find them according to informations you send
My regards
