D-Man
All over it...
- Aug 28, 2008
- 221
- 3
- 0
- Location
- Melton, Victoria
- Website
- www.nextdigital.com
- 99 VT Calais II v6
where's my facepalm picture gone? bah! There's so many things wrong with this quote I don't know where to start.
Anyway, a capacitor will not solve your problems. They are not a magical source of power and won't let you play your stereo for extended periods of time. In simple terms, all a stiffening capacitor does is reduce the voltage drop when the amp draws a high amount of current, such as when a deep bass note is played. Even then, in a real world situation you most probably won't even notice the difference when adding a capacitor to a system. I think they main selling point for a car audio capacitor is to add a blingy looking voltmeter to your boot.
If you want to stop your dimming/drop out problems there's a few things you can try:
1. Make sure you have a good grounding point. The child seat bolt in the parcel shelf is not a very good ground, try the back seat seat belt bolt and sand away the paint first so that you can achieve a good connection to the chassis.
2. Upgrade the factory ground wires.. battery to chassis, battery to engine etc
3. Upgrade the stereo power wiring, however looking at the specs of the amps you are running you shouldnt need to (I don't really know the current draw of a gamecube however).
a capacitor in this sense is just like a battery, the engine makes power, that in turn charges the main battery, in this case with a capacitor set up this will also charge the capacitor (essentially a second battery (which holds electricity(for those who didnt know )) then essentially what you have is a battery.
so then tell me how does this not let me play my stereo over extended periods. if the capacitor is a storage device for power (aka - battery)
