Stugdum
G'day all,
I went to backflush my radiator/heater lines etc and thought I would give the system a going over and check everything while I was there and found an issue which I am not sure about. The question I have is, is the tap turned off with the vacuum servo pulled in or out? I presume it is on when it is sucked in, but am not sure. With all my LPG lines and the converter and everything else the heater tap has been relocated and it is going to be a big PITA to get the heater tap out,and I need the car for work tonight so cant start the job now, because I dont have a new tap yet, just need confirmation about which way is on with the tap is about all for now. The reason I ask is, the heater tap is jammed in one position and wont move, but it seems to be stuck in the open position (vacuum servo pulled in), yet when I flushed everything out it was all as clean as a whistle and flowing well, yet the heater is only luke warm at best when its on full. Any help or advice here would be greatly appreciated. Thanks.
Stugdum
Stugdum
