well I got a ve 06 (comes up 07 on tech2) and I have tis2000 dvd (laptop)
I tried to code in remotes and it says I need tis approval and it doesn't allow it, but apparently for 07 model ya don't need tisweb
anyways decided #### it move on to next thing and did some software update to trans and operating system .. but now all hell has broken loose and now no remotes work and trans and ecu have gone back to stock and I don't have my tune any more but car runs fine
1 question is can ya roll back
2 question is if I log onto tisweb can I code in remotes
3 question apparently if I have level 3 access it should work but ####ed if I can get tech2 into level 3 access
/end rant
You need to go online (acdelco) https://www.acdelcotds.com/acdelco/action/subscribehome
Pay for the service programming 2 days for $55.
And you can load up to date software and it also has a security option that gives the level 3 access you need to sync the tech2 and tis2web for this. I did it on mine and now i can program speedo and other stuff.
Good luck.
thanx for the help
ill get the subscription and give it a try
then ill have to go back to my tuner and have car retuned
then im never touching tech2 again heheh
Hmm, that's a little odd about the remotes. I certainly could reprogram the remotes for my car (though it's an MY08). Can't do keys, but the remotes were fine. I think I may have had to remove the missing one first, and then program the new one. No security access and wasn't using tis2web. Couldn't do the key, but the remote was fine. Just have to find what menu it was under.
well after stuffing around with tech2 and stuffing things up I got the subscription and updated everything and now all works fine
have level 3 access to code remotes
only thing I got now is airbag light on cause update on module was done giving it now coding and it just wont recode back
