Anyone with a VN, VP or VR please help..
SlyVR
Fo'sizzle....
VR Wags
Hi all,
I was looking at my engine bay 2day n thought i better fill up some more coolant.. when i noticed this..
I believe this could be a blown head gasket.. tho not 100%, can some one please help.
My car is a VR done about 220,000... cai and gas system. I have treated this car like a baby!
If someone has had the this problem before please post and any infomation would be great..
Many thanks,
Tim
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
I believe it's just sludge from the holden collant pellets dissolving. mine had it too, but now I use coolant with the pump lube mixed in already = no sludge
YMY-88U
34
Project VH SL/E
yeh, i was gonna ask if u have given it a flush recently and forgotten to replace coolant... well thats what i did, put in the flush fluid and forgot to replace coolant... al good now though
Pretender
Brain function fading .
Sunny Rockingham WA
Pajero LWB Wagon, Power/economy what's that ???
It could point to the start of a head gasket problem but try a flush first as was mentioned.
Check it every day over the following week or so and if it returns take it to a mechanic you trust and get them to check the gas/chemical levels and they will then be able to tell you if the head is leaking. Sorry I always forget the name of the test but it only takes five minutes and most will do it for free.
Torquen
Boost FTW
35
Perth, WA
450+ HP FORD XR6T
its called a compresion test.
Pretender
Sunny Rockingham WA
No not a compression test. Whilst the car is running they draw some water from the radiator. Here it is from a Google search. Sounds stupid but I think the combustion vs compression throw me off so I seem to always forget and no this is not a penis extender.
Head Gasket or Combustion Leak Test Procedure (Gasoline Engines Only)
One method is to use a block tester, also known as a combustion leak tester, to determine if you have exhaust gases in your cooling system. A combustion test kit can be found at your local NAPA, auto parts store. The part number is 700-1006. The price for this part is less than $50.00. Exhaust gases in your cooling system can suggest a head gasket leak, a cracked block, or a warped head, etc. A leaking head gasket can create excessive heat and pressures exceeding the ability of the radiator’s cooling capacity, and should be repaired immediately to avoid additional costly repairs. Head gasket leaks are generally secondary to another problem, such as a clogged or leaking radiator. Make sure you identify and repair or replace the original problem or the vehicle may overheat and cause the head gasket to fail again.
To do the test, add the blue detector fluid to the (block-tester) plastic container according to the directions, and place it onto the radiator filler neck. The squeeze bulb is placed on top of the reservoir and squeezed repeatedly (Some block testers, have a tube that connects to a vacuum line instead of a squeeze bulb). Squeezing the bulb will draw air from the radiator through the test fluid. Block tester fluid is normally blue. Exhaust gases in the cooling system will change the color of the fluid to yellow, indicating a combustion leak. If the fluid remains blue, exhaust gases were not present during the test. The vehicle should be started and at operating temperature before performing the test. Vehicles with head gasket leaks may overheat, and purge hot water and steam out of the radiator. Perform this test, at your own risk, and do not do the test, unless you are experienced and are wearing clothing and equipment to protect you from burns, or injury. For an overheating specialist in your area that is familiar with this procedure go to http://www.narsa.com.
Sometimes, engines with a head gasket leak show steam, water or white smoke exiting the exhaust pipe. Other symptoms include coolant in the oil, or oil in the radiator coolant.
markovr
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Ive had both my cars running like this for a long time .....yes there is that brownish sludge but they dont use any water ....run at at the right temperature and they havent given me any trouble apart from the usual hose replacement .The sludge doesnt hurt anything apart from looking bad to your eyes when you take the radiator cap off.
As long as you follow the usual intervals of coolant replacement everything will be sweet...if the car is running ok theres no head gasket problem.
holden007
VRII
Subaru Liberty
Ive had that brown slug for a long long time (talking 5 years) and had no problems so far. Totally agree markovr.
