jeffmills69
- Feb 10, 2017
- 94
- 8
- 8
- Location
- Melbourne
- 2011 VE Wagon
May be hard to see as videos flipped to the side (easier in full screen). Do they need replacing or a tightening? Cheers
I would also say replace them,
that little bit of movement just with your hands,
will be a much more with the weight of the Car on them, and tension of cornering.
If you can afford it,
Buy SuperPro Bushes for the Front Control Arms, and the Lower Control Arms,
[Or Buy the Complete Set of Arms, so you dont have to press the old Bushes out]
You will never look back.
Keeping in mind, if you do replace the Bushes/Arms, you will require a Wheel Aligment.
I would say replace but that looks pretty min movement. Car drive ok no wobbles ?
You need to take the castor rod out and get some leverage (like a screw driver or something) through the eye of the bush, rocking the rod back and forth like that isn't going to tell you a lot. Either that or get a pry bar against the bushed end and see if there's a heap of play. Have also seen people mount Go-pros in that position while driving to check. As above, symptoms?
Are you troubleshooting allignment issues, noises?
It shits me no end when an alignment shop does an alignment when there is something wrong which a basic check beforehand should have found. The shop should then have called the customer and informed them off the issue and recommended a repair before the alignment was completed.
If the suspension geometry has changed with the replacement of the parts than you may get accelerated tyre wear and/or handling issues. Take if for a drive and see how it feels. If you trust your eye have a good look at where all 4 wheels are pointing when the car is on level ground and the front wheels straight ahead/steering wheel centered.
Half the problem is, they have no idea what to look for...Just throw it on the alignment machine, turn the rack ends until it reaches green and kick it off.....Or when you try and teach the little twirps, they don't want to listen....I'm sure it all interrupts their facebook time
