so I drilled out the 6 spot plastic welds and 4 torx screws to remove the arm rest then drilled out 32 more welds to seperate the door card so as to cover the insert in black suede then put door back together with 38 screws and washers. Very time consuming but resonably easy with a bit of patience
I did the same panels in my VZ in black suede as well. Looks the shizz.
That looks heaps better than the factory look.
I have toyed with the idea of doing the same section in the VE in beige suede rather than the pin hole cream leather of the Calais V.
Where did you source the fabric from?
I used Warwick. The quality was way ahead of anywhere else.
