As car ages, more miles..should oil W rating be changed to suit?
commodoredave
64
sydney
vt
VT V6. 250,000kms
Using the specified 10w30. In times of lower KMs used 15-40 in Summer and 10w-30 in winter.
Oil is changed regularly every 4 months and KMs are maybe 15-16k per year..
As the cooler weather is coming along was thinking of going to a lighter oil say 5w-30.
Has 10w-30 in it now but on a cooler mornings have noticed engine clatter on startup.
Any ideas, views or suggestions.?
vc commodore
Like the Leyland Brothers
VC, VH and VY
My suggestion is, put what you think is suited...
Every thread relating to oil turns to crap real quick with so many varying opinions on which one is better than the next
  • Like
Reactions: Lex
greenacc
Searching for the billion
VE Berlina
No making much sense so far.
15W40 is thicker than what you are using now, and 5W30 is even thinner again. Why have you switched to a thinner oil?
Most people recommend using thicker oil as the car gets older, not thinner oil like you suggest.
Maybe you went too thin and made it more noisy??
Personally I would use at least 10w40 in that engine if it had not been rebuilt yet.
  • Like
Reactions: Lex
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Probably chain tensioners taking a while to pump up then. Not a major issue in my experience as my old VE SV6 did it from about 200k kms to the 330k kms before it was put off the road. Replacing the chain tensioner/s will probably fix the problem.
