Hi Bugs,
I just followed the instruction in the following link.
Ambient Light Sensor Fix | Chevy SS Forum .
The start of the thread provides instructions on how to remove the sensor from the dash.
Posts 139 and 140 provide the instruction to pull the sensor apart.
Post 150 has a picture of the internals of the sensor.
I initially removed all the goop (very sticky) and then realised the heat load sensor was completely exposed. I gathered that the climate control would not function correctly as designed (words chosen carefully because I can never get the temp right) and would be worse. I pulled it apart again and placed the goop over the heat load sensor.
In your case I would just use a razor and ever so gently cut into the goop and remove it bit by bit. When you get close to the light sensor just use your fingers to remove the goop to expose the light sensor. Just need to be careful and patient.
Hope this helps.
