VT2Commie
- Jan 1, 2018
- 455
- 329
- 63
- Location
- WA
- VT2 Clubsport R8
Ok, wait for the Boost Pressure Sensor to arrive then take it back to the auto lekky Astra guru.
Now, the Astra guru MUST carry out this procedure to the letter to calibrate the SAS (Steering Angle Sensor).
1. Get the auto lekky to use his scan tool and go into any other module in the vehicle, one that is programmed correctly to the vehicle (Obviuosly NOT the CIM or SAS). Attempt to reset the ECM/ECU (Engine Control Module/Engine Control Unit) in the reset menu, BUT DO NOT ACTUALLY GO THROUGH WITH A RESET. Now, I don't know what his scan tool has in the way of menus and what not, but it should ask him........(after putting in the security code)
<Do you really want to reset ECM>
If it asks this, then the correct security code IS being used. DON'T ACTUALLY RESET THE ECM, THIS IS JUST TO CHECK IF THE SECURITY CODE BEING USED IS CORRECT.
EXIT BACK OUT OF THE RESET PROCEDURE.
(If the scan tool says WRONG SECURITY CODE when doing the above check, then it really is the wrong code and that is a whole lot of pain in the ass). Did they give you the right code?
Now if the above procedure confirms it's the correct security code after checking, then Astra guru will need to follow these four steps to the letter.
1. Disconnect the battery. Must be disconnected for a MINIMUM of five minutes.
2. Check that ALL the steering components are in the straight ahead position. This includes the front wheels, CIM (Colomn Intergration Module), Or (SAS Steering Angle Sensor). If necessary remove the steering wheel and check adjust the middle position of the CIM (Module behind the steering wheel/clock spring) To check the CIM is in the central position after removing steering wheel, there are a set of arrow markers at the 5 o'clock position on the front of the CIM housing. Ensure these arrow markers are pointing to each other and in line.
3. If battery has been disconnected for a minimum of five minutes, reconnect the battery.
4. Attempt to reprogram/calibrate the steering angle sensor with the security code you got from Holden.
Report back the outcome please.
P.S. Is the original EHU (Radio unit) the one that was out of this vehicle when new? OR have they just grabbed any old radio unit from another astra from a wrecker and chucked that in???
