hi_ryder
Donating Member
- Aug 27, 2008
- 3,359
- 133
- 63
- Location
- Pascoe Vale South, MEL
- vp calais ls1, vp berlina 3.8L
yes to everything ari said...
but... (for me personally) you can prime over 120 but it depends on how long your going to let it sit and how thick primer your going to lay on (to avoid shrinkage). i normally finish anything im going to prime over with no coarser than 180 grit. bare metal you can finish with 80-120 no problem, but with an existing coating you may get a little shrinkage with 80-120 if you prime over it. also id be sanding off as much of that black as possible, doesn't look like it will be a good foundation at all.
also wet finish anything thats right in sight when the engine goes back in with 600 grit (suspension tops ect). some brands of paint can handle wet 400 scratches with out showing lines in the finish after, but 600 is safer.... have fun man....
