Barina horn not working
Pickled
Australia
Car
The horn on my daily 1992 Holden Barina is not working, I've checked the fuses under the dash although they aren't marked at all, I've taken off the horn pad and ensured everything is connected and stable, can anyone shed some light on this issue? Anyone know where I can get a diagram for the fuses under the dash?
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Just because a fuse doesn't look broken doesn't mean it isn't cracked on the side. Have you done anything recently to it?
Pickled
Australia
Car
Well I can't identify the horn fuse anyway since they're not labelled and the car doesn't have a diagram of the fuse layout, it hasn't been working since I got it a few weeks ago, I've had a roadworthy done on it, service etc. I'm actually surprised it passed the roadworthy inspection with the horn not working..
Pickled
Australia
Car
Can anyone help me with this at all? Tried everything and can't figure it out!
Maxxiz
Australian Crapital Territory
2005 VZ SV6
Check the fuses!! Most likely the problem. If theres no diagram.. Look at all the fuses, yeah it will take a while, but not really that long. Then replace any broken ones.. Either that or try find the fuse diagram, ask someone you see in a carpark with a barina. lol
Pickled
Australia
Car
Yeah I've checked all of the fuses twice already, they all appear to be fine. I've looked on the net for diagrams but can't find any, I'm guessing will most likely come down to a cut wire, do barina's have horn relays? Would that have any effect on it?
RSmith
Barina 91MH
Barina Horn Issues
Mate did you fine solution to your horn? have exact same issue, checked all fuses, removed stearing wheel, wiring looks fine etc. Don't surpose you found wiring diagram either?
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
have you applied power and ground directly to the horn itself? the horn could be burnt out
