battery replacement in vs key head
carpetsnake
hi how do i replace the battery in a vs commodore key head 2 button
:bang::bang: tried cant do it
removed the 2 screws and key came out now how do u open the head
thanks
Immortality
Staff member
Sth Auck, NZ
the official line is that it can't be done. you need to buy a new key head (lots of $$$) and then have it programmed (more $$$) on the other hand i have heard people say that if you can pry the head apart without damaging it you can replace the battery. however it is a " do at your own risk" proposition (once my local wrecker had one apart, not sure if it ever worked again however)
jatsvl
NEEDS MORE POWER!
vl exec wagon
replacement remote key heads are $95 got one last week at city holden took them ten minutes to do the job while I waited all they need is the car!
bezz
VK
wreckers sell the keyheads a lot cheaper than that but they still need to be programmed at holden. My new one cost 45 all up.
ranjohn
VR Commodore
thanks
What you do is --- using a hammer, place the key head on a solid bench tap firmly on the edge of the key head working your way around the edge [small but fast taps] you will find that the head will eventually separate. Be extra carefull not to damage the components if you use a knife to finish the separation. You are then able to get to the battery. The only thing is that the battery is soldered in.
VS_Pete
Donating Member
I got a new key cut and head.
My locksmith just put the new key in turned it till lights came on the dash (didn`t try to start car) waited for 30seconds started car head is programmed.
Didn`t go to holden.
