pacey
I'm Back
- Jun 22, 2005
- 360
- 3
- 0
- Location
- Mid North Coast
- VTII 2000 Commodre Exec.
Hi, I know this has probably been mentioned before but be buggered if I could find any thread relating to these problems. Anyhoo, in last past few months the electrical side of my VP has gone downhill and I have been unable to find the cause. Lately, I have had trouble getting into my car let alone start it. Just to make things clear, I'll give a general history of the electrical problems in hoping someone can tell me as to what the problem is.
1. About 3 Years ago I attempted to install driving lights. I accidently joined the wrong wire causing the automatic light switch in the BCM to blow (its that switch that automatically turns the lights off when opening the drivers door), Hence rendering my headlights inoperable. Took the car to Holden and they said they could bypass the BCM and hook the lights up manually or get a new BCM for $400. I chose to Bypass the BCM.
2. Somehow got a short in the car to the point that is was melting and continuously blowing my fuses. One fuse and housing in particular was stuffed (the On Board Computer Fuse). I rewired it and replaced it with a new fuse housing. No problems for a while.
3. Another short, this time melted the ignition wiring harness causing numerous wires to fuse together and rendering my rear tail lights and parkers inoperable (headlights still worked thanks to the above mentioned bypass). Again, had to bypass the BCM (Done it myself this time). Eventually found the problem and un-fused the wires. Bypass no longer required.
4. High Voltage Problem Detected - Could hear the sound of sparking and crackling within the intake manifold (as though there was a major short). Took to Mechanic, told me that is was something to do with high voltage. Neglected to take it back to be repaired. Problem Still exists.
5. Interior Light Fuse continues to blow.
6. All of a sudden the car decided it didn't want to start. After fiddling around, I took the On board Computer fuse out. The Car started straight away. Turned off car, replaced fuse and started it without a problem. (This happened on about 3 other occasions afterwards)
7. Car alarm decided it wanted to go off at 3am in the morning. Flashers indicated that the bonnet had been raised. (Bonnet was secure). Ignored it as a one off. Happened again at 4am and 6am that same morning. Then again the next night. The neighbours weren't too happy. Decided to not use the alarm and just deadlocked my vehicle when leaving it anywhere.
8. This week, I decided to try out the alarm again. 1 hour later the alarm sounded. Turned it off and went back inside. Came back out and went to turn the immobiliser off (The "Press Remote" thingy) so I could start the car, Immobiliser didn't want to turn off. Took an hour for the immobiliser to disengage (my fingies are very sore after that). Now whenever the immobiliser activated, it takes forever to de-activate it.
My only thought is that the BCM is ummm, f***ed and the root of all problems but I can't say this for sure as I have no idea what the BCM controls and if it actually controls the Alarm and Immobiliser as well.
Any thoughts would be appreciated. I'm only on a coppers wage so I'm not looking forward to purchasing a new BCM if it's not the problem. Cheers
