zskinner
- Jan 2, 2009
- 290
- 4
- 18
- Location
- Brisbane
- WN CalaisV 6.0L
Hey guys i have a vp and have just got a front wheel alignment done and was wondering about the printout i got from the company that did the alignment for me. the printout says that my car now has -
* Left Tyre Toe - 1.0mm Toe In
* Right Tyre Toe - 0.9mm Toe In
* Left Tyre Camber - Negative 1.52 degrees
* Right Tyre Camber - Negative 1.86 degrees
* Left Tyre Caster - Positive 3.59 degrees
* Right Tyre Caster - Positive 3.23 degrees
Just wondering if these are all pretty normal figures that would make the car handle ok or if they would send the car a bit wild? just cos after this alignment my car seems to wonder a bit more than it did prior to the alignment.
and theres a bit of a difference in caster and camber degrees on each tyre, are those small differences ok or should each tyre's castor and camber degrees be more closer to each other?
cheers
cheers
