Best rotors for a vs commodore
RATTLEHEAD88
Perth Western Australia
VS Executive S2
What is the best type of rotors for my vs, crossed drilled and slotted or just slotted? I've heard the cross drilled rotors can crack between the holes ( don't know if this is true or not) and what is the best make?
304runner
( .Y. )
40
Central Coast NSW
VR 5.0 Ute & a 4runner with a VS SS trasplant
both are ample to pull you up unless you have 1200hp hidden somewhere .....
VS_Pete
Donating Member
I got DBA Street slotted rotors and Remsa pads from GSL pulls up so much better.
On the VS
sxi ss
50
New Zealand
vr ss
My vr has the zinolli dimple drilled slotted rotors all round no problems with them in the 18 months they have been on there
Jxfwsf
Aus
commodore
it'll all come down to how you drive, if you're harsh on your brakes and like to test them every time you apply them then maybe upgrading the rotors from stock is for you (or you could look into upgrading to vt or ve brake upgrade), if all you do is drive normally then the stock rotors will be fine without burning a hole in your pocket.
aussie bob
Vs Exec S2
I'm thinking of upgrading my front rotors to slotted and drilled with bendix pads only cause I don't have abs for my vs
VS_Pete
Donating Member
If I would have known about the ve brake upgrade earlier I would have done that upgrade.
