ruredi
AVGJO3
- Jul 17, 2005
- 478
- 5
- 18
- Location
- Melbourne
- '12 SS V Z Series Manaul Sportwagon
Hey guys,
Car:2012 VE SS V Wagon. 20" wheels
In the process of fitting new wheels and suspension. I am trying to achieve that semi aggressive / stanced / low look however I am a firm believer in doing things right the first time and I will compromise on not going to extremes in lieu of practicality, drive ability, safety etc - eg. I refuse to have stretched tyres.
At the moment, the car has Pedders Sportsryder Springs with standard struts / shocks.
HTG atm is 370mm front, 350mm rear.
After doing some heavy research, I had decided to go with Bilstein B8's and King Super Lows as the general consensus was that these would out perform any sub $3k coil over kit.
Right before getting them installed, I double checked what heights the car would sit at and realised that it would actually raise the rear 15mm (365mm) and the front would stay the same as it is now (370mm).
I certainly don't want the car any higher than it is now and in fact, I wanted the car a tad lower. I want to close the arch gap. Guard level with top of tyre or few mm below (tucked) is ideal. Doing the measurements, it needs to come down to about 340mm HTG.
Car is currently sitting at 160mm off the ground and I do not have any scraping issues but I am very cautious how I approach obstacles. At 340mm HTG would put the car about 130mm off the ground. I am not sure if I would have scraping issues at this height but I would hate for it to scrape everywhere so opinions from people with cars at similar height is appreciated...
I then decided that I would probably need Ultra lows which would keep the rear exactly where it is now and drop the front 10mm.
However the place where I am looking to get it installed (Centreline Suspension) has advised that this is not a good idea as it will place too much stress on the Bilsteins having them operating at the higher end of their range.
Everyone on hear seems to recommend the Bilstein / King combo so my question to you is...is there a limit to how low I could go on the Bilsteins? Are Ultra Lows ok / safe? What would they ride like on the ultra lows? Will Ultra lows prematurely wear the Bilsteins?
I understand that the B8's lower up to 50mm and from my understanding the car stock is 400 and 410 so the Ultra lows would pretty much be bang on 50mm lower.
The bloke from the suspension shop has recommended BC Racing coil overs and has suggested that these will out perform the fixed combo at the height I am seeking. He has said he would prefer the Bilstein / King combo but he has based his advice on what I have told him regarding my desired ride height. Chris @ Centreline tells me he helped develop the BC racing coilovers for the Pontiac G8's and that they are made in the same factory as the Pedders Xtreme but are better due to having better spring rates etc. Also suggested they are better than TEIN. Price is $2,200 installed. The Bilstein / King is $1,660.
I certainly don't want to spend anymore than $2,200 and in fact I didn't really want to spend that much.
But now I'm having doubts about what to do. I don't want to put something inferior / cheap onto my car. And I'm also not sure I want to put up with scraping the **** out of everything.
However I don't want it any higher than it is now and in fact I would prefer it a bit lower but it doesn't seem that I can achieve this with the Bilstein / King Combo. At best, I can keep it pretty much where it is now by putting in Ultra Lows but I am not sure that this is suitable with the Bilsteins which would mean I would need to install Superlows and raise the car
But I understand I have to make a compromise somewhere and if it means I'll have a much better ride and a better performing product, I might consider not trying to get it so low by putting in coil overs and achieving the look but sacrificing everything else. Chris assures me it would not ride too harshly or like a pig.
What do you suggest?
Advice much appreciated.
FYI - The Ultra Low Part numbers for my car is KHFL-150SSSL and KHRL-152SSLHD. The super lows are KHFL-150SSL and KHRL-152SLHD.
