[QLD] black 202
barrabob
69
ipswich
vk holden commodore
We need help please!!
we are changing a VK black motor from Efi fuel system to a 350 Holley carbie .. set up
THE WIRING HARNESS IS DONE ,....IT COST $1000 ....LOCAL AUTO ELECTRICIAN
now do we change the electric fuel pump or go back to a mechanical fuel pump
gtrboyy
vt ss & lc gtr
If it has mechanical pump on engine could pribably just bypass it as vk-vl are external f/pump.
If tachiometric relay is still hooked up you could also just add a small cheap low psi aftermarket f/pump.
Immortality
Staff member
Sth Auck, NZ
Use the electric pump you already have but add a low pressure fuel pressure regulator.
