Blinker stalk
Ray R
NSW Central Coast
2010 VE Commodore
Hi peeps, anyone out there know how to replace a blinker/cruise control stalk, I have a 2010 ve sportwagon sv6, the left blinker will not engage .Hard to find some info. Thank You..
SV6WGN
40
New Zealand
SV6 SPORTWAGON
You need to remove the steering wheel, which means removing the airbag... (it's not as bad as it sounds)
The stalks are clipped into the clockspring housing its a squeeze the tabs and slide... Make sure you don't move the clockspring as the steering angle sensor is in there too.... I'll try find the vid I used to remove the steering wheel for you...
