blowing smoke after cam install
monaroman76
VN SS
Hey guys just installed a 218/218 blue racer crane cam into my VN SS, The car runs excellent and sounds real nice. I have noticed that it blows a bit of white smoke now, mostly seems to be on start up. What could be causing this? could it have anything to do with the break in lube being used or anything like that?
Cheers guys
VT-565
QLD
VT
white smoke you say? white smoke is generally unburnt fuel.
could it be grey smoke? oil?
monaroman76
VN SS
I thought it was the other way around?
gelousi
west side
Vr Berlina 195i
white/blueish is burning oil, n black is unburnt fuel could be running rich or maybe just valve steam seals and its burning oil.
greenfoam
VP Executive R-spec
Could be running rich. Bigger cams are not as efficient at low revs as the standard cam and will run alot richer. See how you go in a couple days
monaroman76
VN SS
thanks for the input guys. Is it possible it could be my valve stem seals as i didnt change them?
VT-565
QLD
VT
black is burnt fuel whilst overfueling.
white is generally unburnt whilst overfueling. blue/grey smoke as mentioned is usually oil.
gelousi
west side
Vr Berlina 195i
do u need to change ecu or re-map it to run with this cam or just straight bolt on?
monaroman76
VN SS
It started and ran with out the tune, but i never drove it like that. I got a tuned memcal from greenfoam.
greenfoam
VP Executive R-spec
Never mind your smoke for a moment, how does it go :)?
